Dumb stunt tonight, the cost of a great thrift store deal went up
67Dart273
Idaho
Went out to Habitat for Humanity today, and picked up some stuff, the most of which was a bunch of Makita. 18V charger, 3 drills, one of which is dead, and two 1/4 hex impacts.
So I decided to test them, clamped a 1/4 hex to 1/2 square driver adapter in the vise. Chucked up a drill and was playing with the clutch, which seemed worn out. At some point I somehow got it set to "drill" and wasn't prepared when I bumped the trigger. Wrapped my right hand wrist up for about 5 1/2 turns. This may not be happy, tomorrow.
Ouch! It’s unfortunate how things like this can happen in a split second, and often have significant costs. Good luck with your recovery.
Damn, be careful Del. Been there, done that with one of those drills for planting bulbs. Cordless Dewalt on low speed. Down through dirt it went until I hit a root.
Went to the doc, got it x-ray'd. Not broke. The doc estimated might be a month before I am somewhat back to normal. GREAT!!! (not) PRIME wx going on here, it has finally cooled down, just nice, mild fall weather. I might have actually gotten some stuff done.
Got some wrist braces, and for "light" stuff one interesting one that works well is an Ace "thumb hole" bandage.
"It only hurts when I laugh" LOL
It hurt my wrist reading that. OUCH!
The house project has been slow. Got it cleaned out of burn damage, and the damaged areas sprayed, the neighbor used a shellac product instead of kilz. Terrible stuff. He should have had an air supplied mask and did not. And the **** is explosive.
Got the wiring replaced and the "rough" inspection for electrical passed. Got a few outlets hot, which greatly reduces the need for cords strung from the garage, and of course the main house panel is again hot. For warm up on cold days, I have an old electric furnace only running two of the elements plugged into the kitchen range outlet I don't yet have the water heater back on permanent power but could have any time.
I do want to change a couple of things AFTER the inspections are all over with, but it will require some prelim. The way the electrician did this, I am out of breakers. But he put both bedrooms lighting and outlets, along with the short hallway, ceiliing lamp and outlet, AND the bathroom lamp and blower, all on one outlet. I at least want the bedrooms separate, because the back bedroom is normally used for radio/ electronics, AND I won't have a furnace for awhile. I will have to supplement the living room gas heater with electric. The bedrooms and bath have wall Cadet heaters, but they won't be enough. So I'd sure like to have "better" and separate outlets in the two bedrooms.
The wiring is daisy chained at the last outlet, up overhead, back down to the second bedroom, chained around the room, then back up and over into the bathroom.
So I can separate it all up in the "attic" and J box them back together, then stub in a couple extra runs back to the panel area. The plan is AFTER all the inspection **** is over, separate those circuits, connect to the stub runs, and add a small sub panel, either indoors in the kitchen or outdoors beside the existing panel.
I finally got the gas pipe reworked. It did not leak gas, but they require a pressure check and the old sealer won't hold that. Be aware that gas is 1/4PSI (7" water column) and the test is 10PSI, that is FORTY TIMES the working pressure. I have not got it inspected yet, but it held my own test
I got the water system reworked, and finally decided to get rid of the last of the galvanized. All new pex, except for two short pieces of galvanized, at the interface in/ out of the water tank.
What comes before that is what I need to work on. The little ***** (boy) that does framing inspections, knows nothing but crossing t's and dotting i's. I have to caulk and seal up pinholes to please that *****. Meanwhile, the stairwell is and always has been wide open.
But I won't be doing ANYTHING of this for a few weeks, looks like.
They’re making you test to 10 PSIG downstream of the 2# regulator outside? That’s asinine!
We always used to test about 10 but with everything disconnected. In other words just the piping stubbed out. Maybe you are unaware, I have a dozen years in HVAC/R
I am going to refuse to hook to the meter. I am going to get very aggressive. "The gas company has not given me a signed, notarized release to pressurize their equipment. The city has not give me a signed document to release me from liability from the gas company!! In no book, document, or any other place, have I been presented with an OK to pressurize the company low pressure equipment."
I washed dishes last night, that went OK. This thing is tricky. In the morning, I dare not twist the venitian blind operator in the trailer. I HAVE to stop and thing and reach over with my left hand.
My wrists hurt for 3 months after this incident. I feel your pain. Hope you heal up well.
No, I remembered that. I just find it rather odd that AHJ is making you test to 10# on a Residential application. I don't recall exactly what they require here (Twin Cities metro), as I'm Commercial, but I'm pretty sure it's not 10#. Heck, our Installers run 10 PSIG when they do NG piping for Commercial rooftop units, and I've overheard some GC's tell our guys that even that's overkill.
I've been in the office for too many years, I guess, otherwise I'd remember the Residential test pressures.
Good luck!
Edit: Or....Maybe it's because our guys are dealing with Inspectors on a daily basis, and everyone knows everyone, while you're "just a Homeowner" that they don't know from Adam.
The incredibly stupid part is, they require TWO tests. One for rough in, and then one after the walls are done. Now, I understand, what with modern plastic piping, but this is black iron. Not only that but the only finished wall that incures gas pipe will be a 1/2" coming straight in through the wall from the outside.
Are you REALLY going to drive a drywall screw through that pipe?
Not to be gross, but if you had that on video and posted it to your YouTube channel you’d be making mad stacks of cash on that one.
I wish. I’d post that in a heartbeat. It twisted me up pretty good AND as a bonus it electrocuted me. @Turbo440Dart was there helping me with the truck and I’m sure he’d agree video of that would be gold.
Makes me hurt lookin at it. When I was a kid still in school, I worked at a mom and pop machine shop. I had learned the boring bar ( a nice older air cushioned Quick Way) and was doing a finish hone with the OLD 1/2" Craftsman drill with a Goodson 4 stone hone. I went too far down in the bore and caught the main webbing in the block. BEFORE I could let go of the drill, it slammed me into the floor head first. I was OUT for maybe 3 or 4 solid seconds. When I came to and we knew I was ok, all we could do was laugh until we almost cried. It ended up being pretty funny, but I was sore for two weeks. lol
Decades ago, couple of friends and I one evening, I was discussing getting a better 1/2" drill. Roy says, "I have one YOU CAN NOT STOP"
I thought about that for a bit and said, "why in the world would you want a drill that you can't stop? It could break an arm."
When I was in the Navy we had an old B&D FIVE EIGHTS drill that was in one of those accessory clamp on drill presses.
Later, When I worked for the big parts store in town, there was a guy who was weird, walked or hitched everywhere, ALWAYS wore a coat, and carried a long barrel 44 single action Ruger. And bought stuff. Came in and ordered one of the big B&D, I want to say it was a THREE QUARTER!!!
I have one now I cannot stop. brb. Lemmie get a picture.
Here it is. It's an honest to goodness "SkilSaw" brand. I would date it to probably the late 40s or early 50s. I've had it bound up several times and had to let go. It breaks high quality 1/2" shank drill bits like twigs. It's a MAN of a hand held drill. I found it at an antique store. It was marked 25 bucks and Kitty got it for like half. lol
Yea that’s a goodun. Wrist breaker for sure
