Scottrico
Active Member
I am getting ready to order a drive shaft and want to set the front ride height/rake angle for occasional drag racing before I check the drive line angles. I am running Mickey Thompson Street radials P255 R60/15 in the rear with Mancini Racing Springs and Caltracs. On the mostly stock front with PST 1.03 torsion bar suspension I am running Goodyear P235 R60/15. My Question is, should I set the front end height to factory specs which is a height difference of 1 7/8" or should I raise the front a bit to get some more weight in the back? Currently it does look a bit higher in the rear because of the tire size difference and the heavy duty rear springs. This car was originally a slant 6 but I now have a 383 B block and A 833 4 speed trans with a Strange 60 rear end.
