Hideogumperjr
[FONT="]I have read so many posts and threads that my head hurts, there is just so much information some of which is conflicting some of which is confirming and I seek your kind assistance. [/FONT]
[FONT="]
[/FONT]
[FONT="] I am back to initial square 1 with my rear end on my 63 Dart. [/FONT]
[FONT="]Background- Since I converted my stock 7.25 with 9" drums with another 7.25 with 10" drums I have found this one to be terribly noisy. I have been obsessed with dreams about rear ends in late night nocturnal mental emissions and waking spells trying to absorb and understand all the information on this wonderful forum.
[/FONT]
[FONT="][/FONT]
[FONT="]Right now I am unable to sleep with all this info running around my monkey brain and I want to get it down on paper for some help. [/FONT]
[FONT="]
[/FONT]
[FONT="]My story recap, I converted from drums to discs and have the front end aligned now and that is fine but the noise from the rear end is scary and I have minimal trust in its longevity. [/FONT]
[FONT="]
[/FONT]
[FONT="]I have read tons of threads about 8.25s and 8.75s and 8.8s till my head hurts and want to be sure I am on track with it so I can make an intelligence researched decision on my next step so I would like to recoup what I believe I know here for group clarification please.[/FONT]
[FONT="]
[/FONT]
[FONT="]I dont plan on high horsepower on this car, I plan to stay with the /6 working for a mild build for a long while for its fuel economy (gas is 4.50 here) at least for the foreseeable next few years and I have garnished enough information reading from members posts on the pros and cons of the .25 vs. the .75 rears. I also realize that there is mixed judgment on lots of this from all the posts. I am not considering disc on the rear since the 10" drums will suffice my needs. I am also not into laying rubber and am not considering a posi-traction rear-end.[/FONT]
[FONT="]
[/FONT]
[FONT="]So here is what I believe I know:[/FONT]
[FONT="]1. [/FONT][FONT="]The 7.25 sitting behind my /6 may blow out depending on how I take off but Mopar also made many 318s to sit in front of the 7.25.[/FONT]
[FONT="]2. [/FONT][FONT="]I have been told I can rebuild the 7.25 because it is the only way to get rid of the roaring and grinding, but is it economically worth it? Parts are expensive.[/FONT]
[FONT="]3. [/FONT][FONT="]The 8.25 from an A-body will handle up to 400 hp depending on launching and I wont be doing any dragging just enjoying the Delta-V. {I had a chance to buy one in hand for $100 but didnt, kicking myself in the *** now, Alan!}[/FONT]
[FONT="]4. [/FONT][FONT="]The 8.75 from an A-body is strong but expensive to buy and rebuild but for heavy usage is the best route to take if I have lots and lots of power. (This seems way overkill for me so very low on the totem pole.)[/FONT]
[FONT="]5. [/FONT][FONT="]The ford explorer 8.8 will fit in my A-body if I cut 3" from the long side and put a short side axle into the cut side but may have other issues such as E-brake not working, etc.[/FONT]
[FONT="]6. [/FONT][FONT="]A 8.X rear end from a B or other X-body style will push my wheels out further due to the greater width of the rear end but may not be such a bad thing for stability as long as tires are not too big. (Mine are 195 75 R14 all around.)[/FONT]
[FONT="]7. [/FONT][FONT="]I know that jeep discs will mount onto the 8.25 and 8.75 but I dont plan on doing this at this time, but I have one question: [/FONT]
[FONT="]o [/FONT][FONT="]Will a Cherokee jeep rear end fit under my 63 Dart if I change the spring mounts to the bottom, otherwise are there other implications to doing this or is it even possible? (I have one in my sights for $50 BTW)[/FONT]
[FONT="]8. [/FONT][FONT="]Is there any other rear end that will just bolt in under my A-body? What about with minimum modifications? I do have a MIG welder.[/FONT]
[FONT="]9. [/FONT][FONT="]I realize that if I move to the 8.X size rears that I will need to have the drive shaft shortened and the U-joints and yoke issues addressed.[/FONT]
[FONT="]
[/FONT]
[FONT="]I would appreciate corrections, clarifications and feedback on these assumptions because I fear my brain will explode from reading all the posts I have gone over again.[/FONT]
[FONT="]
[/FONT]
[FONT="]Thanks in advance for all the great knowledge on this forum and the terrific help I see given and I have gotten but please be gentle on this worn out soul.[/FONT]
[FONT="] [/FONT]
[FONT="]Cheers.[/FONT]
[FONT="]John[/FONT]
[FONT="]
[/FONT]
[/FONT]
[FONT="][/FONT]
[FONT="]
[/FONT]
[FONT="]
[/FONT]
[FONT="]
[/FONT]
[FONT="]
[/FONT]
[FONT="]
[/FONT]
[FONT="]
[/FONT]
[FONT="] [/FONT]
[FONT="]John[/FONT]
