hey, i picked up an early LA 318 (actually made in 66) and some rebuilt 973 heads. Im trying to make decent power with pretty much no budget at all haha.
first of all, is there anything that needs to be taken care of to mount the 973 heads on the motor? I know there are some smog ports, but oiling,cooling, etc. is all the same?
the intake ill be running is a Eddy performer rpm. So im thinking about port matching the intake to the heads of course. The grind off any casting imperfections etc. (dont have money for a complete port job)
as for the block, i can still see crosshatching in the motor, which leads me to believe its been rebuilt at one time. The pistons have valve reliefs in them but stick down in the motor about a mile. I was thinking of getting the block decked to zero out the pistons (valves should clear with the reliefs correct?) , but im not sure if that would be too much compression for pump gas?? Any input?
And as for the cam, i have brand new flat tappet hydraulic lifters, so im probably going to sick with the cam that is in there. I have no clue whether it was changed out tho. Is there any way to tell? The lifters in the motor are definitely not roller lifters, so im sure its a flat tappet cam, just not sure if its aftermarket spec. Any suggestion on a cheap flat tappet that can make decent power?
other than that its going to be pretty stock. The carb i have is a 650 carter i believe. like i said, pretty much no budget here but i want to get the most out of what i got.
Any suggestions on any of the previous, cam, compression, heads will be greatly appreciated!! sorry for the long post tho :wack:
anyways, thanks guys
and thanks also to the guys who helped me out with the block, heads, and parts, you guys are awesome!
