early V8 exhaust manifolds
memike
Super Moderator
Staff member
on the hill
Shooting myself for selling the ones I had :BangHead: but know I will need a good set, tell me what you have
Thank you , memike
Might be a good compromise between restrictive early A manifolds and headers.
Ever considered magnum manifold swap?
Just a suggestion.
Eric
Just a suggestion.
Eric
I am up for any subjection Eric, privet message sent
I’ve got a set for 75$ plus shipping. PM me if interested.
Jake
Valiant would be the same as a Barracuda, but I've never seen anything other than 340 HP manifolds or Magnum manifolds that will work on an early A....other than 64-66 manifolds. You are right, that the drivers side is restrictive because it has that dog leg in it on a 64-66 drivers side.
What happened to the fenderwell headers, Mike?
I am working on getting them in, I am thinking I will use the Hookers, I need to delete this post, I thought I did brother :popcorn:
An old set of 360 exhaust man. would work on a Barracuda. Less restriction than273. Or would a Vaiiant be different ?
I have yet to see a set of any manifolds that will work, just the 273 man's will. Same as Barracuda, if you can show me or point me in a direction that would be cool Pete .
I have some 64 - 66 273 exhaust manifolds.
Hold tight, I am seeing if I can tackle these myself, if I can't I will be getting back to you :thumbsup: Thank you
I should make myself more clear. 360 exhaust man. Will fit on a 273 in my manual steering non power steering 4sp. Had that setup back in the day before I restored it to original. Hi Mike
I am running a 360 , 904, manual steering, I would love to see an old picture or the 360 manifolds that will work if you could point me in that direction Pete, I understand if you can't find anything :thumbsup:
Hey Mike, I searched for "273 with 340 manifolds". There are quite a few threads about this. Here's one that may help. Treblig's name came up as knowing what's going on with manifolds. He may be able to help.
273 with 340 exhaust manifolds
Meant to say non power brakes. They were early ones because this was approx. 1976
, none power brakes here as well, if you do run across a picture can you put it in this thread please please Pete
Mike, I noticed you're not asking about 340 manifolds from Second gens; Do they not fit your early-A?
I have been doing some reading and from what I have seen the second generation 340 will fit but it's much harder to get them to fit, still learning this myself
