Hideogumperjr
Hi all, I have rebuilt the front end on my 63 Dart and am moving to disc brakes in the front. I installed the control arm on the right but dont know how to set the eccentric cam bolts initially.
As I connected the upper ball joint to the spindle hole I noticed that while the top of the spindle was mostly horizontal, the ball joint looked to be tilted several degrees downward toward the front. Can anyone tell from the pictures if the control arm is correct? This is the passenger side and I have the flat part of the control arm for the bumper over the mounted rubber bumper so I believe this is oriented correctly (but Ill be the first to admit I could be wrong!)
CAn someone explain the correct orientation of the cam bolts when replacing them after bushing replacement? Also if the angle between ball joint and the spindle hole should match or if they are off angle?
I will include pictures if "Gods willing and the creek dont rise."
Thanks and let me know if this makes any sense.
Cheers.
John
Cheers.
John
