ecu and voltage regulator mounting location???
dusterdan
Sublime Member
La Mirada, CA
hey guys, could you please post some pics of where your ecu and voltage regulators are mounted. thanks a million i sure appreciate it! car is a slant six now going to be a small block....
I asjed the same question about the ecu but no replies. I did decide to place it on the left inner fender. The hood may have hit it if against the cowl. Too much water there too.
I put my regulator where the original was. Used one original bolt hole and drilled one bolt hole. A 3/8 long spacer required at that hole.
Joe thanks, your car looks fantatstic! i'm in the market for a 70/71 air cleaner like you have any idea where i can pick one up affordably? i know they're rare but i'd be willing to spend $100-$250
not sure. i bought that air cleaner for $100 in the mid 90's. swap meet, ebay, keep an eye out in the classified section of the different mopar sites. they show up from time to time..
