Post #20. If that is showing the screws all the way in, then there IS a problem. The screw tips should be poking into the t/bore & may not be able to adjust idle mixture as it is now.
Two possibilities:
- the alum plug in the body under the screws is too long, stopping the screws.
- the screw thread inside the body finishes too soon, bottoming out the screws.
Two possibilities:
