Flat-tops, .034Q , closed chamber heads,and Scr adjusted to 185psi, with whatever cam you run. I ran about that on 87E10 at 34* power-timing at 3400, in a 3650 pound blob, me and the car together. It will take 32*@3200, which is all those aluminum heads need on the street.
A) My 367
Static compression ratio of 10.9:1.
Effective stroke is
2.86 inches.
Your dynamic compression ratio is 8.91:1 .
Your dynamic cranking pressure is 183.76 PSI.
V/P (Volume to Pressure Index) is 162........................................ 162
Unbelievable power in a 367.
If you don't know about VP,read about it here;
V/P Index Calculation
B) a stock 1969 440 Magnum makes about;
Static TRUE compression ratio of 10:1.
Effective stroke is
2.83 inches.
Your dynamic compression ratio is 7.79:1 .
Your dynamic cranking pressure is 154.44 PSI.
V/P (Volume to Pressure Index) is 154........................................ 154
Some of us might remember these as the things to beat in the GTX/ Roadrunners......with our little 340M/T As... back in the day.
_________________________________________________________
I tell you what, even the 383Magnum GTX-4-gears were tough; gear for gear, and only to about 85 mph.Then they were catching up......sometimes, FAST!
But after I blew up the 3.55s,I lied about the 4.10s in there,lol; and tried not to beat 'em by too much. Those GTX owners were all the same, after they got beat by a puny Dart.
