Edelbrock carb on factory spreadbore intake
gliderider06
Delaware
Is it possible to mount an Edelbrock AVS or performer carb on a cast iron spreadbore intake? Will one bolt on witb a thick mounting flange gasket? Just curious if it would work or not.
I’ve done this before. Over 20 years ago. I don’t remember the particulars of it but I didn’t have a problem with the carb right to the intake leaking.
I didn’t use that on my OE ‘79, 360 intake.
Thank you fellas! I suspected ot might work and i already have a few of those plates.
Thanks, Paul
When i set my eddy on the cast 340 intake i got,i tried it with no gasket. Looks like it will work fine with the plate.
All you need is Edelbrock #2732. You don't need any of those stupid 1" thick aluminum spacers that always leak.
This one: Edelbrock Carburetor Adapters 2732
Looks like they don't have them in stock. O'Reilly stocks them. Your local O'Reilly should have one hangin on the wall.
Kim,Summit has them now,back in stock.I have used them before,work great
