edelbrock mechanical fuel pump
mad dart,, where di dyou buy your pump ? i have searched jegs and summit,,,both showing nothing on this pump,,,the one add posted here i believe is over seas ??? it shows a us price austrailia price as well,,,103 us money,,, i did a search this pump doesnt come up,,,,thanks
ok heres the scoop on the BIG carter,,,,,went to carters web site,,,part number not found,,,,
called summit,,it is discontinued 6 months ago,,none left,,,i never even heard of it,,,,
rock auto showing a part number,,191.00 not in stock,,,
so why search for one if its discontinued,,,, eddy pump 170 gph 427.00 summit price,,,ouch,,,,
I wonder if you could unbolt the bottom of a 6 valve chevy edelbrok and swap it to a chrysler pump??. like i said above my friend was a poor boy way of doing things but the pump arm swap and he welded it worked good, i also wonder if you could swap the arms from the mopar to the chevy pump?
Dang that sucks even for me if it goes out.....Dang!!
I will do a search and see where you can get one. I will post it here if I am successful.
I would feel comfortable buying from this site using PAYPAL. I would call them first and have them send you an Invoice thru PAYPAL so if anything happens they will refund the $$ to you.....The price is $161.04
https://www.horsepowerparts.com/index.php?content_id=175&product_id=85476
How about here!!!!!!! $118.15
http://www.autotruckpart.com/home.php?cat=286&sort=orderby&sort_direction=0&page=127
THANKS ILL LOOK AND CALL BOTH,,,IM GOING TO LOOK AT THAT PUMP FROM CLAY SMITH ALSO,,,,
YES IDE LIEK TO THINK SWAPPING THE CHEVY ARM may be the hot ticket,,ive been thinking that for a long time,,,if i get get a hold of both pumps or see pics of the pumps at the arm attaching area,,could answer a lot of questions,,,
ok here is an up date on the carter M 61147 mech pump,,, i spoke to the hi performance dept at fedral moguel,,they purchased carter and divided it up,kept what they wanted,sold off the other,,sold AFB carbs to edelbrock ETC,,,
this fuel pump was made from 1996 and discontinued end of 2008,they ran out of stock feb of 2009..and will not make any more,,,
they gave me a number of a place they said stocks there older stuff,,so i called,, he just laughed,,and said they give me no support,,they just pushed you off on to me,,,
this compnay i called is the company that actually builds the pumps,,and does repair on out of production pumps and other items,,,
he is looking in to it,to see if he can build me a pump of this nature,,as soon as i hear back ill update,,,
also all the links on this topic,either have no contact info or do not stock this item either,,,including VP PERFORMANCE down under,,,
one more thing to add,, the clay smith pump,,i have not heaqrd back from them, i e mailed them a week or 2 ago,,then i did a search,,they are in canada,,and closed till the 8th for the holidays,,
http://claysmithcams.com/ppf-17mopara-273-360.aspx i'm going to try one of these when I swap out the electric pump on my setup I have never used one but it claim can supply 1300 hp???
ok here is the latest up date on a high volume mech fuel pump for a small block mopar,,,
after calling every where and every one,, only found 3 options,, 1st the way over priced eddy 172 GPH mech pump around 400 bucks,,
then fedral mogul pointing me in the direction of a guy in MASS that rebuild fuel pump that are noe out of production,,,he said he would build what i needed,using a AC DELCO body and a mopar arm,,but could not give me a flow rating,,said if it didnt work he would refund me my money,,,cost he said at least 250.00
the clay smith link provided by dotchguy is the winner,,clay smith was closed for 2 weeks for the holidays,,and i finally talked with them,,they build them as ordered,, ordered mine today,,will be build and shipped today,,5 days UPS 140 GPH 1/2 npt inlet and outlet,, so it has to flow at least what i have or better being its large inlet and out let,,
im not sure how dotchguy found this link,,it didnt come up any time in my searches,,,but DOTCHGUY thanks a ton,,,the clay smith pump 125.00 plus shipping
wouldnt think it would cost to mutch but you never know lol
i stated a few posts ago,,that place VP down under does not stock that pump,,,and its out of production,,i e mailed them ,,,not sure how ytou guys found it ,,i called any one and every one there are no more 172GPH carter pumps to be had,,,,
i have one comming from clay smith 140 GPH mech pump 1/2 inch inlet and out let,,,125.00 plus shipping should be here by tuesday
ok guys heres the scoop,,,recieved my clay smith mech pump 140 GPH,,, 1/2 inlet and out let,,,take a look dont think ill have flow problems with this pump,,,,,thanks all who replied to this topic,,,140 bucks shipped
Nice looking pump. I am thinking of getting one myself. Let us know if you have to do any grinding. Thanks.
yes i agree great price 125 plus shipping,,,now im going to up grade a few fuel lines and yes i wanna see if it clears with out grinding,,,the inlet and out let are in weird positions,,,,
they sent me a very small catolog
and in the catolog is a bottom plate for thses pumps,,,making the inlet and out let on the bottom if it doent clear your motor with the side inlets, i wish they would of told me when i ordered i would of bought it and only paid shipping once lol
fstfish I bet you can take the bottom screws loose and rotate the bottom section to get the inlet and outlet where you want them. I know on Carters you can and it looks like a similar design.
a carter has 2 bowls that are clockable,,, this pump has the inlet and outlet on the same bowl,,,so if it was rotatable both would turn,,, when i get to it ill mount it and see what i have,,they make a botom plate and plug kit ,,it relocates the inlet and out let from the side to the bottom,,kinda a kool deal,, this pump must be made well its heavy as *&^%$....
Right. Even though they both move you might be able to find an ideal (or at least close) setting for them is what I meant. The relocation kit does sound like the best though.
The Carter pump says it is clockable on both bowls. The bottom bowl is clockable at about 15* at a time but the top bowl MOVES with it. The top bowl will only clock 180* by itself other wise it moves with the bottom. I checked this all out when I installed mine. I guess you could drill some extra holes in it but then you might loose fuel pressure or ?? if you didnt cover up the existing holes that come from the factory. This is from my experience working with this pump. Fwiw
there is one of these carters still for sale on moparts i thin under small block parts or race parts....its new still in the box so if someone wants one better snatch er up! just heads up for you guys!
SHAME I DIDNT SEE IT LOL
