Edelbrock Performer intake on 318.....GAPS?
Small Block Mopar Engine
  1. JeffreyLee
    JeffreyLee 1965 Barracuda FABO Gold Member
    158
    68
    Sep 20, 2017
    meridian Id
    Local Time:
    4:13 AM
    Hi Guys, I received an Edelbrock Performer (Model 2176) intake to install on my 65' Barracuda. The engine is a 1969 318. Finally pulled the engine and got it on an engine stand, pulled off the stock intake and I was anxious to test fit my new intake......Sits fine, but there are sections of the engine that are not covered by the new intake, middle, both sides...It looks strange to me. Is this gap filled by the gasket upon installation or is there something going on here that I should be aware of? Thanks for your advice... IMG-1997.JPG
  2. 65Val
    65Val Average Length Member
    5,051
    1017
    Oct 14, 2005
    Victoria, BC, Canada, EH!
    Local Time:
    3:13 AM
    If you're talking about the middle of the heads, thats normal to be open there. The end rails are filled with a cork gasket, or a wall of silicone.
    • Thanks! Thanks! x 1
    • Agree Agree x 1
    • RustyRatRod
      RustyRatRod Bla de blizhibliz de blatde blizi bla bla FABO Gold Member
      59,947
      31079
      Jun 7, 2010
      Georgia
      Local Time:
      6:13 AM
      Heat sinks for the exhaust crossover. They were exposed with the stock intake, you just didn't notice. Perfectly normal.
      • Agree Agree x 1
      • 318willrun
        318willrun Utube channel 318willrun
        14,103
        14544
        Sep 13, 2013
        I'm here
        Local Time:
        5:13 AM
        Normal, they are left open on them all.... your talk'n about the "U" shaped openings in the center.
        • Agree Agree x 1
        • bbrroowwnn
          bbrroowwnn never re member
          12,293
          719
          Nov 27, 2010
          Drums, PA
          Local Time:
          6:13 AM
          again....as stated before in many other threads....this question should be a sticky as it comes up ALL the time!
          • Agree Agree x 2
          • Darter6
            Darter6 Well-Known Member
            4,113
            1366
            Jan 16, 2008
            Nevada
            Local Time:
            3:13 AM
            You will find 2 dowel pins in the block for the end gaskets.One at the front and one at the rear.Aftermarket intakes are not drilled and the intake will not sit flush unless you remove the pins or drill the manifold. Most just remove the pins.
            • Agree Agree x 2
            • dano
              dano Evil Handy Man
              2,945
              895
              Aug 22, 2005
              Gresham, Oregon
              Local Time:
              3:13 AM
              Looks like your block has a rebuilders tag on it.
              • pishta
                pishta I know I'm right....
                16,988
                6634
                Oct 13, 2004
                Tustin, CA
                Local Time:
                3:13 AM
                you talking these gaps? They are normal too, just a die cut gasket void to nothing.
                • toolmanmike
                  toolmanmike FABO MODERATOR Staff Member FABO Gold Member
                  48,604
                  33261
                  Jan 18, 2006
                  Iowa
                  Local Time:
                  5:13 AM
                  The op mentioned "middle both sides" inhis original post. Normal.
                • Darter6
                  4,113
                  1366
                  Jan 16, 2008
                  Nevada
                  Local Time:
                  3:13 AM
                  Yeah, looking closer now and seeing the tag along with the smear of silicone on the block it's been apart before. If they decked the block and heads the manifold might need a cut to match. Might.
                  • Agree Agree x 1
                  • toolmanmike
                    48,604
                    33261
                    Jan 18, 2006
                    Iowa
                    Local Time:
                    5:13 AM
                    I bought a 408 Stroker a while back and the guys that threw it together didn't pull the locating pins on the China walls. They must have gooped 2 or 3 tubes of silicone to try to stop the leaks. What a mess. The photo is after a lot of scraping. You can see the silicone all the way to the edge.
                  • JeffreyLee
                    158
                    68
                    Sep 20, 2017
                    meridian Id
                    Local Time:
                    4:13 AM
                    Thanks to all my Mopar brothers for the swift response....The gaps I was concerned about are indeed in the middle of the intake. Dowel pins are not there any more. There is a rebuilders tag on the block. National engines and parts Co. Engine stock # 71736 engine code k6990...I cannot find any reference for this company or record of these numbers. I would love to know a little more about the beating heart of my Barracuda. I am actually happy that this is a rebuilt engine rather than just a tired, old 318. Any help would be appreciated.
                    • Like Like x 1
                    • dano
                      dano Evil Handy Man
                      2,945
                      895
                      Aug 22, 2005
                      Gresham, Oregon
                      Local Time:
                      3:13 AM
                      I would pull the timing cover and check the chain and possibly replace with a better one and a tensioner. You might get some grind numbers off the cam if it has any. If it has grind numbers and you can get a cam card, degree it.
                    • pishta
                      16,988
                      6634
                      Oct 13, 2004
                      Tustin, CA
                      Local Time:
                      3:13 AM
                      Stock intake didnt cover those either. The gap is to keep head cooler by isolating the exhaust crossover passage from the head as much as possible.
