Electric fuel pump recommendations?
Fuel and Air Systems
  1. Tonto7
    Tonto7 Active Member
    36
    1
    Aug 12, 2012
    Connecticut
    Local Time:
    2:43 PM
    66 Dart 273 2bbl. Stock.
    Having serious vapor lock/ fuel boiling issues.
    Need a recommendation for a DEPENDABLE full time electric pump replacement for the factory mechanical fuel pump.
  2. A56
    A56 MoParAffliction FABO Gold Member
    1,210
    1146
    Jun 24, 2014
    White Oak, N.C.
    Local Time:
    12:43 PM
    So you're saying your fuel pump is the cause of this boiling over and vapor lock? Would you mind posting a picture of your engine bay, specifically your fuel line and carb?
    • Agree Agree x 1
    • wish4hemi
      wish4hemi Well-Known Member
      840
      113
      Aug 26, 2009
      62450
      Local Time:
      1:43 PM
    • j par
      j par Well-hung Member
      23,632
      12072
      Jul 2, 2014
      Portland Oregon
      Local Time:
      11:43 AM
      I used the red Edelbrock 4-7 PSI...
      They have them at O'Reilly's or AutoZone. They're quiet and work fine. I just recommended one to another member who emailed me a few days later and thanked me for the recommendation as it was quiet and worked fine for him as well...
      My-2...
      • Like Like x 3
      • 318willrun
        318willrun Utube channel 318willrun
        14,889
        15677
        Sep 13, 2013
        I'm here
        Local Time:
        1:43 PM
        I will be trying one as well, possibly on the van in the near future. I think they were like 62 bucks at O'reilly's
        • Agree Agree x 1
        • j par
          23,632
          12072
          Jul 2, 2014
          Portland Oregon
          Local Time:
          11:43 AM
          They used to be cheaper like 42 but they jumped up in price pretty quickly over the last year or two...
          • Agree Agree x 1
          • A56
            1,210
            1146
            Jun 24, 2014
            White Oak, N.C.
            Local Time:
            12:43 PM
            and these are external mount?
          • j par
            23,632
            12072
            Jul 2, 2014
            Portland Oregon
            Local Time:
            11:43 AM
            Yes just an inline fuel pump with a positive and a negative...
          • j par
            23,632
            12072
            Jul 2, 2014
            Portland Oregon
            Local Time:
            11:43 AM
            • Like Like x 1
            • A56
              1,210
              1146
              Jun 24, 2014
              White Oak, N.C.
              Local Time:
              12:43 PM
              Nice, I wouldn't want the in tank set up personally.
            • A56
              1,210
              1146
              Jun 24, 2014
              White Oak, N.C.
              Local Time:
              12:43 PM
            • RustyRatRod
              RustyRatRod Bla de blizhibliz de blatde blizi bla bla FABO Gold Member
              61,724
              33736
              Jun 7, 2010
              Georgia
              Local Time:
              2:43 PM
              You can do just fine with a pump mounted on the frame rail in front of and below the tank. Make sure to run a return system with a regulator if you want the best of benefits from an electric pump.
              • Like Like x 1
              • Lord Sparky
                Lord Sparky Well-Known Member
                272
                190
                Dec 2, 2019
                Carlsbad, California
                Local Time:
                11:43 AM
                Do you have a spacer under the carb?
                • Agree Agree x 2
                • RustyRatRod
                  61,724
                  33736
                  Jun 7, 2010
                  Georgia
                  Local Time:
                  2:43 PM
                  Probably one of the most overlooked things ever and will solve 90% or more of these type problems.
                  • Agree Agree x 1
                  • diymirage
                    diymirage HP@idle > hondaHP@redline
                    19,455
                    13438
                    Oct 12, 2012
                    michigan
                    Local Time:
                    2:43 PM
                    I betcha a simple return line will solve all your problems while keeping your mechanical pump
                  • toolmanmike
                    toolmanmike FABO MODERATOR Staff Member FABO Gold Member
                    50,424
                    35410
                    Jan 18, 2006
                    Iowa
                    Local Time:
                    1:43 PM
                    Or a fuel return type filter. @Tonto7 when are you experiencing problems? Extended cranking after sitting for days to weeks? Hot soak? (shutting it off and hard to restart after sitting a while) Or are you having issues while driving?
                    • Like Like x 1
                    • 512Stroker
                      512Stroker We are all here because we are not all there.
                      1,535
                      1077
                      May 30, 2016
                      Freedom, MO
                      Local Time:
                      1:43 PM
                      Adding an electric fuel pump is a band-aid solution.
                      You should not require a electric pump to keep it from vapor locking.
                      You have other issues you need to solve first.
                      • Agree Agree x 3
                      • Thanks! Thanks! x 1
                      • RustyRatRod
                        61,724
                        33736
                        Jun 7, 2010
                        Georgia
                        Local Time:
                        2:43 PM
                        I agree with that, BUT it sure helps eliminate problems with ethanol laced gas. People who don't have issues don't know how easy gasohol vapor locks under the right circumstances, plus there are areas of the country that use over the 10% limit a lot of us have. An electric pump with a good return system does help in those situations. But I do agree 100% that the SOURCE of the vapor lock should be addressed even before the addition of the electric pump and return, otherwise you still may not fix the problem.
                        • Like Like x 1
                        • Agree Agree x 1
                        • dodgedifferent2
                          dodgedifferent2 Well-Known Member
                          2,526
                          349
                          Aug 8, 2008
                          southwestern, Ontario
                          Local Time:
                          1:43 PM
                          I ran 3 external pumps and all mounted lower than the tank. All three left me stranded. I ran a walboro pump twice.
                          Paid the price and switched to an aeromotive phantom in tank pump and have not had an issue since. I learned my lesson and would never use an external pump again.
                        • RustyRatRod
                          61,724
                          33736
                          Jun 7, 2010
                          Georgia
                          Local Time:
                          2:43 PM
                          Sorry you had trouble, but the fact is a LOT and I mean a LOT of vehicles have had great success with frame mounted external fuel pumps both in the aftermarket DIY world and right out of the factories. In fact, some new vehicles still use them, so that puts their use well into the millions, perhaps even tens or hundreds of millions since electric fuel pumps have been put in use.
                          • Like Like x 1
                          • Agree Agree x 1
                          • 512Stroker
                            1,535
                            1077
                            May 30, 2016
                            Freedom, MO
                            Local Time:
                            1:43 PM
                            EFI or carb?
                          • 512Stroker
                            1,535
                            1077
                            May 30, 2016
                            Freedom, MO
                            Local Time:
                            1:43 PM
                            OP do they sell premium fuel without ethanol near you?
                            • Agree Agree x 1
                            • DentalDart
                              DentalDart Well-Known Member
                              2,500
                              1534
                              Jul 5, 2019
                              Las Vegas
                              Local Time:
                              11:43 AM
                              I dont like hearing this... i have been having fuel percolation/vapor lock issues... never had them before installing cam, lifters, cleaning the engine (internally). Added 1/2in spacer as well...
                              Hot vegas heat, hot asphalt, hot engine bay and the carb doesn't get the fuel.... my car has maybe 50 miles since the new parts all installed because percolating/ vapor lock issues.
                              I'm looking at adding an electric fp and running a return line as I dont know what else to do.... I'd love for you to share your wisdom with a young grasshopper who just wants to drive his car again lol. I really don't want to drop the gas tank in my garage for a the return line though. :(
                            • Mattax
                              Mattax Just the facts, ma'am FABO Gold Member
                              10,773
                              6757
                              Feb 7, 2013
                              Phila. Pa
                              Local Time:
                              2:43 PM
                              You do not need to drop the tank to put a return line in.
                              Use a fuel sender/pickup unit that has the 1/4 nipple for a return line.
                              That said, I agree with 512stroker especially because you wrote this didn't occur before you changed cams etc.
                              So what's different now?
                              not the things listed in the beginning here.
                              On what basis do you know the carb is not getting fuel?
                              I'm not being an ass here. I'm asking what the basis for coming to this conclusion is because vapor lock can occur in different locations and show up in different ways.
                              Using the specifics, one can begin to narrow what/where the issue is.
                              If you have a thread covering this - then just link it.
                              PS. Off topic Speaking of heat. Route the output wire through the clip.
                              • Like Like x 2
                              • Agree Agree x 1
                              • Mattax
                                10,773
                                6757
                                Feb 7, 2013
                                Phila. Pa
                                Local Time:
                                2:43 PM
                                And where is the fuel filter?
                                I'm headed out but you can do a search here for how Chrysler recommended mounting the fuel filters to help let vapor escape.
                                • Agree Agree x 1
