abodyjoe
ok.. what is the summit ign? that the same as the chrysler set up only summit brand?
should goto the side of the ballast that has key power. pull both wires off the ballast and stick a test light in them. the one that lights the test light when the key is turned on is the side that the ign should be hooked to.
