Engine bench test
Dodge73Dart
1973 Dodge Dart Sport restoration
Asheboro North Carolina
Automatic Transmission pulled out. Would like to be able start engine without installing transmission.
Any suggestions?
Also if I leave the neutral switch wire disconnected will I get ignition or do I need to jump a connector?
You need a bellhousing to mount the starter, and a flywheel for it to turn, and yeah you'd have to bypass the NS switch.
A bellhousing with an old converter works well.
Use a flywheel with the proper balance.
Nonsense. You are not going to be winding the engine up very high or for very long. "Back in the day" (70's--80's) I ran a neutral balance 340 wheel behind a 360 for a couple of years in an old Landcruiser, and ran it pretty hard, too. Yeh. It shook. It was LONG before Al Gore invented the internet.
I don't even use a bell. Just a flywheel and the engine plate off the scattershield. But you could MAKE that if you can fabricate. Just use the automatic for a pattern. If you are afraid of breaking the starter round up a junkyard cheapie and gamble with that. So far, so good
I was disagreeing with using an unsupported old converter. As far as proper balance you can do as you wish. It makes no sense to me to balance an assembly $$$ and then run the motor with the wrong setup.
Get a fuckin flywheel and bell, keyyyrist.. it's not do or die trying people, holy ****! Lol
Make or buy a stand, it's easy and cheap.
