If you go with pipe max recommend average port velocities (fps list below) 260-300 average fps = Very good HP & TQ, if you put that into port sizes, eg.. would be around 250 cfm = 162 - 187cc, 300 cfm = 194 - 224cc that's a fairly big window and that's for very good, add in the windows for good and ok fps, the port cc windows are even larger for any given cfm.
So your very unlikely to have enough port size to put you into slow 225 fps or very slow 210 fps eg 250 cfm = 216 - 232cc thar's a lot of port for 250 cfm.
