The right side mount needs an ear cut and welded to the other side of the mount. The left side just needs a spacer.You dont NEED to move anything, Just bolt old ones onto the frame, drop the 340/360 in and shim the driver side gap you get with 4-5 washers.
That works on the left but what about the right. Without cutting the one ear and moving it to the other side to re-weld it you will end up with only two ears bolted to the mount.Just add a 3/4" nut to upper driver's side bolt, as a spacer.
