Engine Paint
DentalDart
Ozark Missouri
The paint on this engine is flaking off a little. What’s the best way to strip the paint off and repaint it?
Thanks.
I don't know, but good to hear from you, Doc! Merry Christmas!
Thanks! Merry Christmas to you as well!
I’ve been around but haven’t done much car work as the office is nuts at the end of the year and I have 5 projects at home going on.
Car goes to paint in January so I’m going to have to **** or get off the pot with things on it.
70 and sunny here for Christmas
I can't think of a good way without totally stripping it down. You could try scraping the flaking areas off and wiping them down with lacquer thinner or even brushing on paint stripper first. It would be tedious and messy at best.
Take it to a bare engine? Or you just mean pull the heads and accessories off?
It depends on how you are going to remove the paint and on what quality of paint job you want. If its going to be a chemical bath or bead blast then totally disassembled and bare. I doubt you would want to go to that length. If you are going to try a chemical stripper or lacquer thinner then just remove the manifolds, water pump, intake, etc.. I suppose it depends on what kind of paint job you want in the end and how bad the flaking/adhesion is. Perhaps try chemical stripper or lacquer thinner in a test area and see how easy the paint comes off. Just my $0.02.
I just don’t want it to flake off. It’s an engine that’s never been run, and going in a car that’s getting repainted and redone.
If its flaking before its even run then I suspect adhesion issues likely due to poor prep. There is no real way of guaranteeing good adhesion without totally stripping the paint, cleaning and repainting. Like I mentioned above, I'd try a chemical stripper (not on aluminum) or lacquer thinner in a test area and see how easy the paint comes off and what you are in for.
Great question. I repainted my 340 that was red with black hi temp paint. It cracked-a lot! Original paint was said to be Mopar performance engine paint I’m going to try to wire wheel/wire brush mine to get off what I can. I wiped the whole thing down with thinner but wondering if adhesion promoter would have helped?
Start with an air nozzle. The flaking paint is not adhered well and it will blow off. Hot pressure washer is good also.
Then start in with the chemicals and strippers.
Thank
Several ways to approach this, depending on what you are willing to do, and what your goal is. If the paint is flaking, it wasn't prepped properly. Spray it with a good cleaner, let it soak, then use a good pressure washer and it will quickly remove the badly adhered paint. Painted areas that remain could probably be painted over, or use wire wheel and wipe down with acetone and/or pressure wash again to get it all off. I like VHT engine paints and recommend their primer as well. They also make a high temp engine clear that helps with appearance and durability. A more involved repaint would use spray gun 2 stage paint, but I have had very good luck with a well prepared block and VHT paints without the need, expense and hassle of cleaning paint guns.
Once you paint an engine with auto paint with hardener you will never use another rattle can. Does not need primer, to many coats are not good on an engine with the heat cycles. Adheres well and will not discolor with fuel, oil, or degreasers.
The quality and durability is unmatched with rattlecans.
I don't disagree with any of what you said. Unfortunately where I live it is difficult to get the colors you need as many paints are not allowed here due to VOC content. I painted my car trailer a few years ago, using a gun and paint from an auto paint supplier. I had to use two different hardeners plus the paint. It was about $400 for materials and a lot of stress. I realize its my fault for living in CA, but even places like Eastwood can't ship certain paints here. Touchups are much easier with a spray can too. You gotta do what you gotta do. I too, would recommend a good quality 2K paint if I could easily get the color match and it met my needs. I can't even get denatured alcohol here anymore due to VOC limitations, but I was able to get it on Amazon labeled as "camp stove fuel".
Well I don’t agree that rattle can paint is the best.
The best way is to strip every last bit of paint off the assembly weather that is mechanically or chemically just do it. The last time I had one of my 440s prepped it was tumbled and was like it had been sand blasted. From there I apply a couple coats of epoxy primer and automotive single stage paint, I’ve also used rattle can after the primer usually semi gloss black but now I just use black epoxy primer on my race 440.
Here’s my 452” painted New Kubota orange single stage on the pump. It’s actually an industrial single stage urethane.
Bill Hersch paint.
First strip then hit it with degreaser, then with a map gas torch, then soap & water, rinse, paint.
scrape the flaking portions well, clean it with BrakeKleen, let dry thoroughly and spot in the problem spots with the same engine paint you used in the first place. Is it really flaking before you even ran the engine? sheesh - who's paint did you use???
This one was fresh from the machine shop so it only needed to be cleaned, but we shot it with Motor Coater enamel paint through a cheap HF gun.
scrape it, wire wheel and brake clean. anything that holds up those three isn't going anywhere...
as far as paintin it goes..
clean it, clean it and clean it again then epoxy prime it then spray a high solids urathane on it.. that **** is bullet proof. paint supply housese can even mix that stuff and put in in a spray can if need be.
if you can't find it in your area then i'm sure someone here could buy it and send it to ya. :)
We all understand prep ( as IN CLEAN) is the key.
A good epoxy primer will stick to even slick cat C***. Good epoxy.
Metal needs to furnish surfae to bit as in not slick and NOT OILY!
I have never had any adhension issues, and never used a primer. The primer will not hurt.
I agree, any automotive acrylic urethane/enamel with hardner is better than the average spray bomb.
Good luck!
