thesiren74
408 atk's kick ***!
If you are good with hands and tools and have some sense, and are willing to read and listen closely, and not go too radical, then you have a decent likelihood of success on your own. My first performance engine was one I built and I had not done a complete motor before; I read and read and read.... and read some more. And asked questions at the local shops. But the dilemma is understood. The advice is because the crate engine route is a bit of a crapshoot; you may very well end up with a decent piece, or not.
What auto work have you done before, if I may ask? And what are your long term goals and plans for your car?
There are plenty here who can help you with any math. You can do something pretty nice with that budget.....my son and I spent about that much for a 340 at near 400 HP with new Edelbrock Performer heads, new SCAT rods and KB pistons, new intake, hydraulic flat tappet cam and so forth; pretty much a complete new parts build. And a 360 would save a few bucks over the 340. You might PM Dartvader; I think he did his own engine for the first time and he is easy to write to. (And maybe Straightlinespeed and maybe BadSport too).I can replace parts pretty easy, I've done most the work on my duster, I even took auto in high school, but the thing I know I would have trouble with is all the ratios and all that stuff I would have to do
I just want a engine with more horsepower but I am not going to be drag racing or nothing like that. Just to cruise around. Yeah I will have time to invest!
Contact MRL, you'll be more than happy. If you provide your one block, get a late 80s/early 90s LA 360 Roller Block.
I don't know man, I had Mike build me a 408 and I had all sorts of things break
3 days after I installed it the rear end blew up
a month later my high/reverse drum in my transmission went out
so if you decide to have Mike build you one, be ready to spend some money on the rest of the driveline so it can handle the power![]()
Well who was the buttmonkey that ran a 7 1/4 behind an MRL stroker again? ummm......YOU?
LMAO
That's a bold statement that actually assumes a good bit.The term 'value' in the phrase "Value Power Base Crate Engines" likely means it has shortcuts on parts quality.... just be prepared for problems as they occur all too often with such purchases.
Seen it with a Ford and a MoPar big block here as well from other companies.I've seen a Chevy LT1 factory short block missing half a main bearing, right from Chevrolet...
I knew a a kid who built his first car engine at age 15. It was a 283 for his oil-burning 57 Belaire. The only special tool he bought was a torque wrench. It ran great for at least one year, til he sold it and used the money to buy a 70 Swinger340. He was an over-eager, try-anything, snot-nosed, law breaking, godless, young punk. If that guy could have success, with no other help than the data sheet, how much more success will you have? Well I'll tell you; Tons and tons, I expect.
Yeah that punk was me......and the year was 1968.
