To measure, mount indicator and spin 360 degrees.
Mark the largest # on the bell, then zero out the indicator on the opposite side, 180 degrees.
Spin again and record the largest number.
This is done because it's difficult, if not impossible, to set the dial indicator on the exact centerline of the crank.
Mine had a .020 maximim total indicator reading, aka offset, with 0 on the opposite side.
Moving it .020 will just make it .020 off on the opposite side.
I used .014 dowels, moving it .014 for a total offset of .006.
Mine must not exceed .008 maximum total indicator reading. That's any radius along the circumference.
So, if my max is now .006 with 0 on the opposite side, the max number from the center is actually half of that, .003.
And yes, I measured again, and the max is now .006.
Half of .006 is .003, which is damn good, imo.
