Are any of the other bolts tightened up all the way? i know I never have any luck starting bolts when one is cinched down.
true true, start each bolt just a wee bit and move on to the next bolt
Guess I,m late to help any.Glad to see your getting the 68 done James.Some shims or washers might help with hedder clearances.Waiting for a vid of fireup!!:cheers:
Is the starter tightly mounted? I see a loose nut.
x2 thanks cracked,lol it was like your a mindreader the whole thread!lolIf you can jack the car up and turn the wheels it will give you room to clock it up in there.
It's not tough.
Wow, thanks for that one. I didn't know there was a mini mini starter. Are they all clocked the same?
Where did ya get the mini mini starter from and it goes to a 97 Dakota?
All that trouble even from a very expensive and so posed to be a easy bolt on.No thanks cheep headers for me.sorry to have seen all the problimsssss.
yes rob, i loosened that nut after the fact. i figured it out and found an even SMALLER mini starter. its from a 1997 dodge dakota 5.2
hey snake, really isnt THAT bad. I just had a few hiccups...my dumbass had the motor mounts on backwards at first, that was a TOTAL newbie mistake...i was thinking since there were 4 mounting provisions cast on one side of the block and 3 cast on the other side, naturally, i thought the motor mount with 3 holes went on the side with the 3 casted provisions and the 4 bolt hole mount went on the 4 hole side of the block....its awkward that its totally opposite.....LOL
but yea, the regular mini starter not clearing was kinda BS, but easy fix, i found a mini mini starter. I had to give a 100 bucks for it though from NAPA. LOL
only problem im facing now is the passenger side header is up against the torsion bar...a shim kit is on the way...but the engine needs to go lower...so maybe shim the driver side mount??
