Can you move the engine slightly to the drivers side?
Lowering the tailshaft might help a bit.
Maybe try taking out the trans mount and moving the tailshaft around to see what happens?
I was half thinking about suggesting putting it in with the old mounts just for a looky. But Holy Hell, that's a bunch of work.
Try loosening both motor mount studs where they got through the k-frame then do a leg press on the passenger's side header from the outside of the car and see if the engine shifts. Looks like engine is sitting too high on passenger's side. Hold tight you will get it figured out. Those a-body k-frames are sloppy. Some people get lucky and some don't. Definately get the TTI instuctions and measure that engine location:
http://www.ttiexhaust.com/PDF/II_TTI340A.pdf
I'll bet money his headers weren't bad. He jumped the gun and beat stuff to death.
You have a bunch of non-factory stuff in there. You need to find the happy place where things line up. It take some effort sometimes.
I know you mentioned that you didn't think the engine could be moved side to side because it was tough to get in, IMO, that's just not correct. You can move them a bit from side to side once the mount stud is in the k frame.
It's gonna be tight no matter what you do, it's the way these cars are.
Maybe he needs to modify the slot in the k-frame like I did? Hard to say because all these cars are different. Some people just get lucky and the headers clear everything. Sounds like he is saying if the trans could sit lower everything would clear? I wonder if that would mess up the drive line angle?
well i tried it again, still nothing. trans is bolted up, engine hanging on the hoist, lowered it down untill everything clears, not even the stock motor mount will work, there was not enough room between the motor mount and the k-frame to install the biscuit mount. the motor had to be lifted up....
i have the motor mount brackets loosly bolted to the block, all bolts are in, but just loose so the bracket can move. both mounts are like that which would allow the engine to settle where it needs to be once i slowly lower the enigne down with the hoist..still, the headers hit the torsion bar, and just slightly rub on the steering box....i honestly cant think of any other ways. ive exhausted all my other resources, dunno now...
maybe ill just go with it and let the f*%#ers rub on everything. at this point i dont give a ****....
Yep,might have to get some solid mounts made up(thinner).Sucks but you got do what ya gotta do.Good luck.Or go custom motor mount brackets. This looks like a very unusual case here for sure.
Have you tried it with your old torsion bars?
So motor has to sit lower then the mounts allow before everything clears?
time to just throw on some 340 manifolds and call it good
