Exhaust Flange rough !
Rbob
Olympia, Washington
Exhaust manifold to head looks good, however the flange to exhaust pipe is not pretty.
Took it to my machine shop and they don"t have a way to clamp / fixture the manifold to do this.....
I may post a pic but you get the idea,
Any ideas???
Photos would help. Years and years ago, I used hi temp silicone on headers with good results. Might even be somethin' better nowadays.
Manifold gasket surface at the head-pipe? Some machine shops have what amounts to being a really big belt sander. They're frequently used to resurface the head side of exhaust manifolds and both sets of flanges on attached intake/exhaust manifolds, like used on the /6's, so that they stay the same thickness.
Failing that clamp it in a vise and try a bodywork type long board with 36 grit. Be careful to not alter the angle of the flange and to keep it flat.
I've no hope that JB-Weld is a long term fix for that kind of heat.
