factory 383 A body throttle cable housing length...
ph23vo
seattle
my car has 98% of its orig parts... however the throttle cable was broken by a prev owner and replaced... it barely reaches the clamp so its obv short, looking for the correct length of just the housing .... i heard 67 was different..not sure..... only original 383 a bodies that are known original...lmk thanks
Yes 67 was different because it used an AFB instead of an AVS. I will see if I still have my original cable from my 69 if I can find it...
YES BUT ITS MOUNTED IN THE SAME PLACE..[SAME BRACKET AND KICKDOWN IN 67,..CABLE HOUSING SHOULD BE SAME...CABLE ITSELF MIGHT BE A TINY SMIDGE DIFFERENT THANKS
Best I can do ya' from the firewall on my '69 without removing. A 383 car I've had since'81 ...
THANKS..LOOKS LIKE MAYBE 13 1/4 TO TIP OF METAL PART? IS YOUR BRACKET THE ORIG ?...REALLY APPR IT MY FRIEND
I should have an original one maybe an NOS one. I will look later
At the Mopars in the Park show all weekend, too burned out to go to the shop today, but will be there tomorrow to take a look for it.
I just bought a new (aftermarket I guess) big block throttle cable through Classic industries. I can measure that if it would help you .
I found mine today, it's a little singed from my fire, but still should be good enough to measure, I will do it shortly...
the "housing" has the cable inside it... i do not caer about the cable... just measure from the firewall [washer] to the end of the metal tip where the bracket clamps on.. [where cable comes out at engine side]
SO FAR NOBODY CAN HELP IT SEEMS... JUST NEED MEASUREMEMT FROM FIREWALL TO END OF HOUSING [JUST TO WHERE CABLE COMES OUT TO HOOK TO CARB] OFF 383 A BODY 68-9...
