I think in the altitude, your big cam, lower compression, and 3.23's are taking away what you hoped for. I bet with a stock magnum cam it would come to life.Oops, 452 heads, stock. Did have them rebuilt with new seals and Howard’s springs
That's disappointing. My low compression 360 with 3.23's and stock converter runs that without slicks and no posi....![]()
I did that absolutely on purposeInsert Batman slapping Robin, "It's a Sure-grip, not a posi!" Meme.
A milder cam might be the easiest solution.I think in the altitude, your big cam, lower compression, and 3.23's are taking away what you hoped for. I bet with a stock magnum cam it would come to life.
@ 5400 ft you'd be lucky to run 14's. lolThat's disappointing. My low compression 360 with 3.23's and stock converter runs that without slicks and no posi....![]()
Well that's good. One you can rest up from and the other is permanent.Same. I thought it was because I was just retarded and had to re-read it twice.
Fortunately, I realized I am just tired, not 'tarded.
That's the normal Chevy and Ford go to. 2500 is a stock converter for Chrysler.A 2500 is whats recommended by Howard’s for this cam. Not sure on flow but they’re 452 stock heads no porting done. I will have to look into calculating the exhaust thank you.
I lived in Colorado, and drove many a classics in colorado, I know what it pulls out of them@ 5400 ft you'd be lucky to run 14's. lol
Interesting. Seems like all signs are pointing to a cam changeThat cam & a 3.23 axle are not going to be winners in the 'taking off' derby. Too many fail to take notice of the very high rod/stroke ratio of the 383/440 which prompted this warning.
10-30What weight oil is in this engine?
37 total. Is this with or without the vac advance plugged in?Just did a 360la to 440 swap and honestly thought the 440 was going to be quicker.
Had to cancel my dyno tune appointment tomorrow due to snow. Was wondering if you all see anything that stands out as a weak spot in the build that could be hindering power?
Running 19 initial, 37 total, vac advance, have the curve setup how I want it.
Haven’t touched the carb, Quick fuel said go down 1 jet size (I believe) for every 1,000’ of altitude and I’m at 5,400’ but the plugs look good to me, medium tan color
Everything is brand new:
9.38.1 compression (calculated)
Bored .030 over with Speed Pro forged pistons and moly rings
Completely balanced
Cam and crank tunnels align honed
452 heads stock unported with Howard’s springs specs for the cam
New cam bearings
Howard’s Roller .530 lift, 235/243 dur, 103 CL
Howard’s roller lifters
440 Source roller rockers
Custom Smith Bros push rods
Aluminum 440 source water pump housing and pump
Carter street super m6903 fuel pump
Melling standard oil pump
Edelbrock Performer RPM intake
Quick Fuel Slayer 750cfm carb, vac secondaries, 1” spacer
Lokar stainless braided throttle cable
K&N air cleaner
CVF serpentine system
Stock ignition box and ballast
MSD coil
MSD spark plug wires
Schumacher Tri Y headers
Schumacher engine mounts
Pypes 2.5” stainless exhaust with Street Pro mufflers
Hughes 2500 stall converter
3.23 gears
727 reverse manual valve body
Completely balanced
New cam bearings
K&N air cleaner
MSD coil
3.23 gears
Let’s revisit the CR-
-What part number pistons, and set at what deck clearance?
-heads were measured and the chamber volume is?
-gasket bore and thickness(or part number)?
