figures wanted - front alignment
lilredridinghoo
lower saxony
hi fellows... just to come around to ask you:
what figures do you use for the best front alignment
camber ?
caster ?
etc...
i had my car adjusted by a friend and the handling on street was okay.. but now after one year my tires are going baldy on the inner side.. and i get more problems with faster cornering (even more if the road is little bit wet)
so, if i buy a new pair of tires, i will also have my front adjusted the right way to get the best out of if
(if it is necessary - shocks are koni red, and i´ve added a addco sway bar)
