I did notice ol’Kim’s mills lay down some steam!
This might be a 4.150 stroke 4.375 boreYep! With a 4.25 stroke and .010 over, it’s a 502.
And 383 -> 496 (4.250" stroke/6.535" rod)
or
383 -> 426 at the stock bore,
438 (4.31 bore, 3.75" stroke/6.760" rod)
So those short deck blocks are worth a little something after all. LOL!
Only in lift. IIRC, that purple .590 is 271 if not plus @050. I hear good things about that purple cam!Got almost the same results with Trick flow heads. Only my cam was smaller, I used the Mopar .590
264/271@50
626int/626exh
105°lsa
Yes, that’s a great cam in a street strip 440. KimOnly in lift. IIRC, that purple .590 is 271 if not plus @050. I hear good things about that purple cam!
