Mad Dart
Nothing to see Here!
35lbs on the Oil Pump. As far as the windage tray, I just tighten them up snug by feel using some Red Locktite.
First, stay away from HV pumps!
I never do a break in with open headers just for the exact reason Steve suggests not to. You cannot hear anything except exhaust. That's all well and good and fun when you KNOW the engine is broken in with no problems, but until you get to that point, I would highly suggest muffling it somehow. Header mufflers are cheap and you could resell them.
What, they came stock in the 340's and work fine for me. Its better to have the clearances n the loose side and the HV pump feeds more oil and cools the bearings off.
Oh sure, they suck up a tad more hp, big deal
Stay away from 4 inch stroke in stock small blocks, IMO
Oh now I'm starting to see
Build the engine with tight clearances and low volume oil pumps so the stroker engines with too short of piston skirts won't burn too much oil way too early due to poor ring seal. Limit the oil being thrown on to the cylinder walls
Well maybe that works ?
But no thanks, I stick with long skirt pistons that don't rock much
If the bearings clearances aren't too tight to start with, they all live a nice long happy life so long as they get a steady flow of clean oil all their lives.
If the engine is built correctly and everything double check as its build, there really should rarely if ever be a problem.
Now sure, if you go sticking in a 4 inch crank in a block design for a 3.5 stroke crank, try to run as tight as clearances as possible to limit the oil being thrown on the cyl wall, then sure. You better listen closely for any noises.
Old school may not always make the most hp but it can save much grief later on
Thanks. i have mufflers clamped on, that issue is taken care of. the carb will be done this morning. then break in will follow shortly after, probably in 3 hours.. about the cam yea, i agree, its a lil big but its together and its all i got for the moment. talked to one of the engine builders over the phone on here where i got my heads..., he said, although not ideal, It'll run and perform fine. so i have gears and a 3000 stall to help me out a lil. I do appreciate everyones input thus far. thank you all. hopefully i can get a video for yall.
