I have the assortment of holley pump cams. It has a .31 nozzles in it. I bought some .35s but haven't tried them yet. Thanks for the tip and will try it out. The trouble is I can't test this on the street because it doesn't bog unless it hooks. BFGs don't hook
Make sure you adjust the bolt with the spring on it, You don't want the pump to bottom out. Set at WOT, get a gap about .015 or a little less.
What cam is in it now?
Try the #35 and see what happens
