bamamopar
Ss need long shocks
Which shocks would you run? I have heard c body and ss shocks. I'm having the same problem.
Ss need long shocks
Old Man Rick: Thanks for the info, yeah I think a converter is needed for sure but I do drive it a lot on the freeway (30 miles one way) so I am a bit worried about trans temps. Thanks for the advice on just trying to stall it as high as I can and launch. The car launches soft and the stall and street gearing making it ssssllloooowwww out of the hole.
Motor:
10:1 360
X Heads that are supposedly ported but I dont know
Edelbrock Air Gap
Demon 750cfm Vacuum Secondaries, green pump cam 72/80 Jets (if I went with any higher Jets the car surged and was super rich so I settled on this for jetting)
Comp XE284 that was advanced to the + marking on the comp timing chain so I assume an additional 4 degrees to the additional 4 degrees built into it.
TTI Headers
MSD Everything with 2 silver light springs in it
The car launches straight, the front end lifts slightly, and the rear end hardly squats down, only a little bit. Very soft launch with wheel spin.
My Dad took video that I will try to upload of one of my runs.
Total timing = initial timing (18 ) + Mechanical advance (18 ) = 36
The lighter springs means the engine reaches total advance at a lower RPM. I bet the red bushing gives more mechanical advance so you are probably getting more total advance then you think.
What is the pinion angle? Changing the pinion angle can change the reaction of the car during the launch (squat versus rise). In the video I didn't see the rear end of the car make any significant move up or down.
In this run I ran I think it was 13.71 at 101 and I stalled it up to about 1500 and floored it. Very soft launch with this converter, but its a 2400rpm converter, what do you expect.
