1. dano
    dano Evil Handy Man
    2,680
    689
    Aug 22, 2005
    Gresham, Oregon
    Local Time:
    8:02 PM
    Do you have that set up from CCP? If you do what brand of fuel pump did it come with? They have a 10% off now on all their stuff.
  2. ed1946
    ed1946 FABO Gold Member FABO Gold Member
    119
    39
    Apr 24, 2019
    garrison, ky
    Local Time:
    11:02 PM
    Yes thats what I have. Don't think I noticed what brand, already installed so can't ck. I ck'd pressure and it is what is advertised at engine compartment. No leaks after install, only ran the one hose for supply to efi. still haven't purchased efi but am leaning toward holley sniper. probably won't buy until ready to run engine which I have yet to install.
    • Thanks! Thanks! x 1
    • reddog
      reddog Well-Known Member
      85
      51
      Jul 30, 2009
      Davisburg, Alberta
      Local Time:
      9:02 PM
      I too, run the fuel command center. Have had no problems with it. Need room for it and it needs to stay cool if possible. I believe most of the problems people have had is heat associated and some have modified them to allow a fuel return to the tank to keep fuel cool. My battery is in the trunk so this opened up the perfect spot for it. Fitech now has a new version of the FCC, I understand.
    • oldkimmer
      oldkimmer FABO Gold Member FABO Gold Member
      13,270
      2980
      Nov 11, 2006
      Kindersley, Saskatchewan,
      Local Time:
      10:02 PM
      So do any of these guys have a pump assambly that will fit into a fuel cell? The kind that bolts in from the top as a fuel sender would? Thanks. Kim
    • famous bob
      famous bob mopar misfit FABO Gold Member
      14,714
      5072
      Aug 14, 2011
      okla
      Local Time:
      10:02 PM
      I have seen them , but didn't pay much attention , due to not needing one ----------maybe Summit or Jegs .
    • famous bob
      14,714
      5072
      Aug 14, 2011
      okla
      Local Time:
      10:02 PM
      Glad u don't have any problems , but u will with that air filter one of these days !
    • my68barracuda
      my68barracuda Well-Known Member
      990
      645
      Dec 6, 2009
      Indianapolis IN
      Local Time:
      11:02 PM
      I put a Tanks Inc tank and pump in the 68 Barracuda when I went with FI. Nice stuff, I would not do it any other way. If your existing gas tank is in nice condition, sell it after the swap. One thing that I did was cut in an access hole to the fuel pump. If I did need to service the pump, can do without dropping the tank. I am in the process of setting the car to run on E85, made changing in the larger capacity pump easy.
      • Like Like x 1
      • reddog
        85
        51
        Jul 30, 2009
        Davisburg, Alberta
        Local Time:
        9:02 PM
        Other than it is a cheapy with foam element with i suppose a risk of melting if flame back from fitech. What other issues, please educate.
      • 69_340_GTS
        69_340_GTS Well-Known Member
        3,686
        1582
        Jul 11, 2014
        Torrington, CT
        Local Time:
        11:02 PM
        They don't filter much. Look at the size of the holes in the foam. I had one for a while, and found visible sand inside the carb.
      • plumkrazee70
        plumkrazee70 FABO Gold Member FABO Gold Member
        2,325
        590
        May 5, 2013
        Medford, Oregon
        Local Time:
        10:02 PM
        Aeromotive makes one. I'm not sure on part number, but my dad has one in his fuel cell. I'm sure summit has a listing.
      • famous bob
        14,714
        5072
        Aug 14, 2011
        okla
        Local Time:
        10:02 PM
        Will disintegrate w/ age , and put the small foam particles in ur engine , probly wont really hurt the engine , but kinda nasty , and filtering ability gets worse and worse.
      • reddog
        85
        51
        Jul 30, 2009
        Davisburg, Alberta
        Local Time:
        9:02 PM
        I guess we are OT from original post a bit here.
        I hear ya. The foam seems reasonably dense but I have no micron rating for it. There is possibly bypass happening around the filter too. For degradation, I will keep an eye on it. Will change it out in time if I can find a suitable quality low profile one. Only have around 2" and then I get into clearance issues.
      • ed1946
        119
        39
        Apr 24, 2019
        garrison, ky
        Local Time:
        11:02 PM
        doesn't bother me, all good info
      • famous bob
        14,714
        5072
        Aug 14, 2011
        okla
        Local Time:
        10:02 PM
        Got that , this is with a torquer 2 , now have a victor on it , and its even worse. IMG_0474 (1).JPG
