Floor shift steering column question
Tony Barracuda
Tallahassee Fl.
Im swapping over to floor shift and bought a column from a member here. I’m rebuilding it now. Is the shift tube on a floor shift model supposed to have a shift tube key? Seems on column there is a key and screw. Mine doesn’t so it lets the shift lever housing to move about 45 degree. Now remember we are working on a floor shift model so the shift lever housing is just the housing. Is this normal???
I.I.R.C., it can be dependent on what year you’re working on. We’ll need some details.
So mine doesn’t have the shift tube key like the picture. So the housing moves with in the slots. And I don’t remember if it did that before I took it apart.
