Found 340, cannot read the vin pad
barracudajohn
whitehall pa
Maybe I didn't clean this enough to read the stampings, or it is blank ?
Looks blank to me, what year block? Date should be cast into other side. Motor machining data is stamped below head on drivers side.
The block casting date appears to be 8-21-71. Can you clean it up a bit more?
Is that the little melt off overheat thing in picture 2?
could just be an offer the counter , mopar parts house supplied . they used 340 in the marine division as well . i think even a reverse rotation for twin screws boats .
There's a little rust still on that pan rail pad. Start scraping with a good straight putty knife or similar.
