Front disc brakes locking up, 72 Duster
I adjusted the push rod length very slightly and tested it without lockup. I'll drive it again for a longer distance to confirm.
I've gotten great feedback and I really appreciate everyone's comments.
Hopefully it's solved but I will report back if there are any issues.
Thanks to all.
Yes. That probably did it. The industry has gotten sloppy with tolerances. I had the same issue after a master cylinder replacement on my Ford truck.
Wrong M/C having a residual check valve in the front line.
You can remove them or easily rupture them with a small nail. Those WILL NOT create anything close to lockup
