front disk
green1
Orange Park, Fla
I installed discs on the front of my 70 Duster. Have a set of 15" cop steelies with 275/50. No go. Will a LBP 14" fit around the brakes?
I put a set of disks from a 73 dart (single piston) and I run 15" cop car rims too and dont have any clearance problems... What disk setup do you have?
Masterpower, rear single piston. I mocked it up with 15" steelies, 225/70 tires, and they are going to rub front fender.
Oh. I thought you meant they would hit the caliper. I think that 70 series tire is giving you problems. I run 225-60-15's on mine and they fit fine but its close
If the brakes are 11" brakes, 14"s will fit fine, if they are bigger than 11", then you will have to go 15"s
