Front grill parking lights go out when headlights are turned on
68 Coronet RT
68 GTS # 508 in Registry
Upstate New York
I have a 68 Dart GTS and when I turn on the headlights the two parking lights in the grill turn off. Is there anyway to rewire them so they stay on when I turn the headlights on.
^^Exactly correct^^
The later cars with "stay on" parking lamps simply wired the parking lamps to the headlight switch tail lamp terminal.
After looking at the diagram does the jumper go on the light switch itself or is there a junction box I can go to and put a jumper on.
I know of no other place the two points are in proximity. The tail lamps go down to the left kick panel connector, the parking laps head out the bulkhead connector into the engine bay
The other thing you might consider.......on my 67 the parking lamp housings are pretty small. If you are not using LEDs the extra heat might damage them
