Well checked the ground its all good and the other two wires (A black and yellow and a black and green wire) running off the turn signals are getting no power I checked and cant find power anywhere to them so Im stuck.
First question is, "do you have a shop manual?"
Usable diagrams here:
http://www.mymopar.com/index.php?pid=18
73 Dustable:
http://www.mymopar.com/downloads/1973/73ValiantA.jpg
http://www.mymopar.com/downloads/1973/73ValiantB.jpg
The signal and park power comes out of the bulkhead connector, so probe that and see if you have power there. If not, it is most probably a problem right there at the firewall connector
AN ASIDE:
The wiring for the side markers "looks" complicated, but it's simple. THERE IS NO ground for the side marker lamps, here is how they work
One side of the side marker is connected to the park light circuit
The other side of the lamp is connected to the turn signal.
With park lamps on, turn signals off, the side marker gets power from the park circuit, and "goes to ground" through the unpowered signal lamp filament, so the side marker lights up, a much smaller bulb wattage than the park or signal lamp
With the park / headlights ON, and you turn on the turn signal, the side marker LIGHTS when the signal lamp is OUT, again grounding through the filament of the unlit signal bulb. But with the signal lamp LIT, now we have power at both sides of the marker lamp connection, so the marker goes OUT while the signal lamp is LIT
Now, with the park lamps OFF (daytime) we have the OPPOSITE condition. When you turn on the turn signal, and the signal lamp is LIT, power is applied from the signal circuit to one side of the marker lamp, and it "gets ground" through the now UNLIT filament of the park lamps, and so the marker lamp lights
Now, just what have you checked? Remove the park/ signal lamps from their sockets, and CAREFULLY probe the socket with a test lamp. Tape up the lamp probe to help prevent shorting, and make sure you have a good ground at the clip of the test lamp. If necessary, make an extension clip lead up so you can ground the test lamp back at the battery or block.
If you don't see power at the socket(s) go back to the bulkhead.
What have you done to "check the ground?"
Turn on the park lamps, and if you have power at the socket, install the bulb, wiggle it around. Now take your grounded test lamp, and "stab" the probe right at the side of the socket. If the test lamp lights, the socket is NOT grounded.
This is a SIMPLE circuit. You have three wires to run the entire show.
The park light power comes from the headlight switch, runs through the bulkhead, and "y's" off to each park light bulb
The front signal power comes out of the column connector from the signal switch, "y's" off to the instrument panel indicators for left and right, and goes through the bulkhead, through the lighting harness, and up front to the connectors for the sockets.
