Fuel Pump Install
KOZ45
Indiana
While my alternator is off and I am doing some work on my Duster, I figured it would be a good time to upgrade the fuel pump to something non-stop (Edelbrock 1723)
Is it as easy as removing the stock pump and installing the new one?
Was just concerned about something falling out of place inside the motor where the pump arm extends........
Thanks
That pump arm rides along the outside surface of the eccentric that’s bolted to the front of the timing gear on the cam shaft. Nothing will move when you pull the pump out.
Thanks...........do I need to put any sealant on the pump gasket or on the pump itself?
I wouldn’t think so. The gasket has a couple holes for the bolts that’ll keep it properly lined up during the install, but as I’ve been reassembling my engine I’ve been reading through the various related threads here and found such a variety of opinions on the subject of gasket sealing that the only thing I can say for certain is that I can’t say for certain. LOL
I haven’t installed my fuel pump yet, so hopefully someone else will speak up and we’ll both know.
I always throw a little Moly or Lubriplate on the end that contacts the eccentric so its got a little somethin' somethin'.
Got the new fuel pump installed....thanks for the info
The pump push rod slide down to the access allen cap head plug (possibly when removing the stock pump)
I removed the plug and pushed it in as far as it would go and then installed the new pump
Time to shop for a fuel line kit now, a new tank, and sending unit
Well I guess all the small block info did no good for ur big block. That’s why it’s nice to have info such as year, vehical and engine size. Kim
