1973dusterkid
Watch This
OK so I took my dash out because my gas hand and temp gauge were not working I found out some wires were lose hooked them up and the gas hand worked but temp did not work all others gauges work the gas hand read 1/2 tank which I think was right well one day someone stole my gas and the hand read 0 fuel so I put gas in and it did not move I took the dash back out and every thing was tight so I could not get the gas or temp gauge to work o well.well I went to put gas in the car thought it was low only help 4 dollars but gas hand read zero so I look and fount some plugs in the floor and side were the petal's are were unhooked but cant figure out were they go here are some pics this is a 73 duster and the wire coming from the fuel tank is blue.Also the fuse box is not labeled so I don't know which is which.I dont kniow whats wrong with temp gauge.
