Gas spills when refueling
since we are talking fuel tanks and systems, I have some questions.
first, I need a simple removable fuel tank while I am fabin' on the rear.
need to move the car, and
I want to sort the brakes /electrical /cooling before buying and installing a new tank.
any safe cheap options? 2-3 gal is plenty
second, clueless on the replacement tanks
mine is a 72 w/ charcoal, how hard to go simple vented?
and what is the config of the replacement tanks?
do they all fit the floor the same?
will have to run all new lines anyway but would love to ditch the canister
(it's ugly...lol)
My 62 Valiant definitely has a horizontal run, literally.
My 67 Barracuda, I wouldn't consider it horizontal, it should have enough liquid gas in it, especially when I fill it slow, but same result each time.
Scroll back up through this thread, find the info on restrictor plates, buy and add one, and drive happy.
I'd love to try one. Are you 100% SURE that will fit into an early A body filler tube hole? The actual entrance hole is a good bit smaller than 2". What do you do? Kinda go in sideways and then straighten it out?
Doesn't solve the issue, but this is how the Aussies handled it.
At least it keeps the fuel off the paint.
I found this website regarding a restrictor, is this it?
SHOP BY CATEGORY | pollutioncontrol2
I have this installed in my 64 Valiant. It helped more than anything else. It still spits at the end (California pumps), but far less than previously.
I had gone to the point of installing a Neon filler neck at one point. Unfortunately the automatic shutoff constantly kicked in and filling was a painfully slow affair so it defeated its own purpose.
What's different on a CA pump?
I think I'd rather try a grommet first, possibly with some holes drilled in it, that doesn't solve the problem, before I jam a piece of serrated metal down it, that may or may not work.
yes, correct. they are the bellows design.
I was just doing some reading and it looks like the vapor recover pump nozzles are going away in many areas. Since 1998 vehicles under 10,000 GVW are required to have a filling vapor recovery system on the car making the station vapor recovery system redundant and sometimes an issue. It said the decision to eliminate the requirement was a state by state decision.
Looking at the outer edges of the restrictor, after installed, could you seal the open edges with a fuel resistant sealer like JB WELD to reduce the gas puke?
A vent that goes past the restrictor is another path to spit when the level comes up to the restrictor in the filler and vent. I've never seen any oem restrictor type filler that didn't put the filler vent between the restrictor and the tank. When they do have 1/8 holes, it is usually because there is a pocket where fuel would get caught outboard of the restrictor that needs a drain.
Another filler option is to make the ring/restrictor (1-5/8" od, 7/8" id for 13/16" nozzle clearance), then at a distance that ensures the nozzle tip side hole will be clear to suck air from the tank vent passage, cut a slot half way through in the top of the filler tube, insert the ring (which would block the vent passage as-is), drill three 1/4" holes down through the vent wall just behind the ring toward the tank end, then weld up the slot (securing the ring) and three 1/4" holes. It would look original except for the welding on the tube.
I used on of DamRaider's adapters to put a flip top cap on my Dart. One unexpected benefit is a chrome plated rim around the filler opening that is deeper than the sheet metal recess in the quarter, making a fuel proof entry with more effective area for paper towels when I fuel. Not 100%, but much better.
