LovetheA's
Before I posted this problem I checked with the how to section and looked up any info on the site dealing with installation of sway bar bushings. What I found was that any way you slice it replacing rubber oem bushings with polygraphite PST sway bar bushings is a royal pain in the ***. I’m finding this out firsthand. I was able to get the old rock hard rubber bushings out with a small chisel and hammer no biggie. I saw that some members have had success greasing or lubing the hell out of the bushing and the inside of the bracket then forcing the bushing in. Up front I should say that you have to slide the bushing into the bracket after the bracket is on the bar. The reason is that when the busing is inside the bracket there isn’t enough area for the bushing to spread enough to slide over the round sway bar end. The issue I’m having is two fold. First, how in the hell lubed up or not can you get the bushing pressed into the bracket on the bar? Seems impossible. Second, is it possible to boil the bushing to make it pliable enough to pop in? I though a petroleum based grease shouldn’t be used on a polygraphite bushing it could compromise it? What about dish soap or silicone lubricant? Maybe I should take it to a shop with a press and pay to have it done rather than knocking myself out? Any suggestions?
Carl
Carl
