Good Streetabe Power
Point of the thread ain't about what you can do with a 318 but what you can do with only 224 degrees of duration.
"Only" 224 degrees is subjective. Comparing to factory camshafts, that's getting pretty big. That's "about" what the factory 340 cam was and they weren't slouches. Especially if you use the solid lifter variety, you'll have something.
Sure it ain't small but it also ain't overly big, it's still in the range of being fairly streetable for most, just before what I'd consider more of a street strip type cams 230-250+.
Good streetable power?
500 sounds about right:)
Probably could with a bbm and the right top end, but I'm thinking where most live in the 300-450 hp range.
Here another interesting one for streetable power on a bbm 431hp 383
Comparing two HFT cams 214 vs 231 vs a roller 214 which gave the best of both.
Camshaft Comparison Testing
CamPAWCOMPCOMP
Part Number1032321-227-4Custom XFI*
TypeHyd. FTHyd. FTHyd. Roller
Adver. Duration280/290275/287264/276
Duration @ .050214/224231/237214/224
Lobe Seperation112110112
Lift (inch).442/.465.525/.525.530/.530
*Lobes 3013 intake/3035 exhaust on a 112-degree separation with 4-degrees advance. Call Comp's cam line for custom cam orders.
Dyno Results
383 Cam Test SuperFlow 902 Engine Dyno
Torque
RPM214/ 224FT231/ 237FT214/ 224HR
2,800413381425
3,000417405430
3,200427422438
3,400436432446
3,600441437451
3,800441445453
4,000440448452
4,200439448453
4,400438447453
4,600435446452
4,800429443447
5,000420434439
5,200406425426
5,400390417416
5,600375407404
5,800360391389
6,000344375372
6,200316361NR
Horsepower
2,800220203227
3,000238232245
3,200260257267
3,400282279289
3,600302300309
3,800319322328
4,000335341344
4,200351358362
4,400367374380
4,600381391396
4,800392405409
5,000399413418
5,200402421423
5,400401429428
5,600400434431
5,800398432430
6,000392428424
6,200373426NR
Power Averages 2,800-6,000 rpm
Avg. TQ415.9425.2433.4
Avg. HP344.8355.3360.8
Legend:
214/224FT:
214/224-Duration; Hydraulic Flat Tappet.
231/237FT:COMP XE275HL; 231/237-Duration; Hydraulic Flat Tappet
214/224HR:COMP Custom XFI; 214/224-Duration; Hydraulic Roller
There is literally no logical reason to ever build a 318 except maybe for fuel economy.
For the most part, but why does have to be logical ? Out of all engines out there is even the 360 the most logical engine to build ?
Thanks for correcting me, you're right. There's no reason at all to build a 318. Great catch!
When you get to a 2.05 or 2.15 intake valve size there is
Who would use those size valves in a stock cast iron head or stock block for that matter?
No one.
On top of that a 224 cam is not suitable for those size valves.
This thread was not about all out race engines.
Yes I agree there's really no reason to build a 318 over a 360 or whatever engine beside /6 and 273, other than you want to, all the reason anyone needs.
When I was younger I would have done the modern hemi swap, that would be logical at the time.
That, but really the most logical even though not a fan of the swap would be an LS, availability, parts, support, ability etc..
Man your talking to a guy that had a 63 Nova with a 327 and 4spd for his 1st car who jumped on the Mopar wagon after driving my cousins 68 383 Super Bee.
You don't pollute a Mopar with a brand X engine, you just don't.
You finally say something I can agree with.
