MOPAROFFICIAL
If it has tits, it's a liabilititty.
Now after reading that, yes it could be the needle n seat.I think I found the problem. Was leaning out choke and hit the throttle to set choke and fast idle. When I looked down carb throat the secondary's were very wet. Car has been sitting for a few hours. This is vacuum secondaries and car has not been running. So I will take carb off and go through. I suspect the needle and seat are not sealing. Am I right thinking secondary's should be dry?
Dual feed or transfer tube?
