Green Bearings and Studs?
blackace
The KING of flats
New Joisey
Like I stated in another thread I bought a set of Yukon axles. What size suds are you using? I was thinking of going with 3"! Any draw backs with going that big? Also the stud hole is 0.645 but it doesn't seem any one offers studs that size? I know I must be missing something because I know there are quite a few guys using these.
Also where did you get your green bearings from other than Mancini and Summit?
I had to get the studs thru Mr. Gasket, sorry, I can't remember the part number. The studs that were supplied with my Yukon axles were to big. The 3-inch studs can be covered with a small hub cap, other than that you will have to use an open end lug nut.
