yellow rose
Overnight Sensation
Fans!22
Water pump 5
Fuel pump 1
ignition 4 or .7 per 1k
O2 sensor 1?
Tac it's light and the little water- oil-voltage gages 2?
And then you need to know how many amps the alternator puts out at idle and cruise. It's nowhere near max rating.
My cousin has a fire chicken that is essentially stock. Had a 55 amp alternator on it. The alternator light would flicker at idle and and the volt meter never went over 12 volts.
I tell him so many times my front teeth are worn down that his alternator was JUNK. He, being the genius sandwich maker he is, went on the old interweb and every single hero on the web told him it was grounds, voltage regulator blah blah blah.
Finally, I got sick of telling him the same **** over and over and over, I jumped on summit, bought his dumb *** a single wire 100 amp alternator that put out more amps at idle than his junker did at max RPM and had it drop shipped to him.
Bolted it on an there it is. Fixed. The spark plugs even cleaned up at idle a bit.
65 amps is a puny alternator. You almost can't get enough amps at low RPM with today's stuff.
