MRL Performance
Well I got a call one day, and this customer wanted a BBM for the street. Wants 15" vacuum, good street manners, dependability, pump gas and 550+HP. So I thought "470"! Good stroke combo for a low deck, good rod ratio and light assembly.
Here is the run down
400 bock prepped and ready to go
3.91 crank
6.535 rods
27cc dish pistons (9.60 to 1)
Edelbrock E Street 75cc heads
RPM intake
Voodoo solid roller cam 243/249 @ .050"
QF 850 Hot Rod carb
FBO ignition system
7qt pan
MRL to end oiling mod
PRW SS roller rockers
MRL solid roller lifters
HP Valve job and Mild port cleanup
I wanted to keep the compression down, yet have a good tight quench so we went with a 27cc dish piston and the 75cc heads. This way he can run any pump gas premium no matter where he ends up. It idles well and sounds Bad *** at 950-1000rpm pulling 14-15" of vacuum.
Its a Ground Pounder for sure , laying down 600+TQ from 3800-4500 rpm. It peaked at 610TQ from 4000-4200! And the best part is it made 550+TQ from 3000-5550 rpm! Torque? Yeah we got some of that!
Now on the other end comes the reliability. Peak HP came in at 5600 rpm. Thats nice as he wont have to rev the life out of it to get ALL the power. It made 583HP at 5600. 500+HP from 4300 rpm on up.
The fuel curve was nice and steady, running 12.9-13.5 for the entire run. BSFC was .400-.355. Again, Waste Not Want Not! VE was 95%+ for most of the run peaking at 98%.
We achieved our customers goal and then exceeded it without sacrificing durability or drivability. WIN WIN.
3.91 crank
6.535 rods
RPM intake
QF 850 Hot Rod carb
FBO ignition system
7qt pan
