cudajim
cudajim
Now that I have my manifold leaks fixed I want to solve the problem with hard starting when cold. My 225 6 banger has always been hard to start. If a crank it long enough and pump it a lot it'll start eventually. I know it's a gas supply issue. I'm running a stock engine but have a super 6 2bbl carb setup. I have a new gas tank, new stock mechanical pump, filter etc. Once running it starts right up. The automatic choke is working just fine too. I'd rather not use an electric pump unless I have to. I'm also running orange box mopar electronic ignition. Any suggestions?
