Majestic
I have bought pulley after pulley and none have worked. I think my harmonic balancer must not be seated all the way. Anybody have any measurements or should I just try to tighten it.
That looks like a cast iron 360 damper...
73 was the only year for a cast iron crank in the 340.
awh....google...
Note: In 72, the cast crankshaft replaced the forged crank in production on April 11,1972 with 340 engine #HM340R-3911-8000. Damper stamped Use with 340 cast crank only
Um no they also came in 1972.
Question for the original poster, are you using the new 1970 and up style timing chain cover that has the timing marks on the drivers side, if so I can measure from the back of the cover to the edge of the balancer to give you an idea if it is seated all the way on.
Nothing unique in production changes mid-year..... So with a '72 340, you just gotta be aware of the change.So they pulled it ahead for the last two months of production for 72...
Our 340's damper is about 1/8" from the raised timing mark area, and the back of the damper is about the same distance to the mounting ears of the timing cover. (It varies from 2.3" to almost 2.5", depending on where I measure to.)
(BTW, our damper is a neutral balance with an earlier crank.)
So what is your fit issues with the pulleys?
