Harness compatibility help
Dk.03
Active Member
Newcastle, DE
So I recently bought a full body harness that was for a 1974 duster and I wanna use it in place of my butchered 1973 duster wiring harness. I believe the dash harness is compatible because it looks extremely similar to the harness that’s already in the car. My problem comes when I was comparing the engine bay harnesses. Looks to be a noticiable difference. I understand it’s a different year harness for a different car and it should be different. I just wanna know if there is specific things I should be looking out for, if anyone who has done this before can help it would be appreciated. I’ve never done a harness before and I’m trying to do everything right the first time.
1973 duster, automatic with 360 la small block, I don’t know if having this matters or not.
Idk what the 1974 duster was
You need to get BOTH manuals and an ohmeter/ continuity tester and do a wire by wire comparison. One huge and annoying difference is the 1974 ONLY seat belt starter interlock.
IF YOU DO NOT HAVE a 74 manual, SEND ME A PM I can send you a digital copy for a little bit of shipping and you send me a USB mem stick
I’ll try and find the manual online but if I can’t I’ll pm you. Also what do you mean the seat belt started interlock? Does this stop the car from starting and is their a way to bypass ?
You can dig around the ' net and compare photos and diagrams of other standard '73 and '74
for example
Before you get too deep:
If your car was equiped with a rear window defrost grid, then it got a modified harness.
If your car was equiped with a 'fleet' alternator,but no rear defrost grid, then it got a different modified harness.
Contact Evans wiring, they are great, very knowledgeable, easy to talk to, and can customize the harness as nec.
It may be more cost/time efficient to just buy that segment.
Good luck.
Let me add that the diagrams are useful but you will probably be best off by laying out both harnesses on a bench.
Label the connections and then compare.
Examples.
Note that my statement in that thread about Packard 56 connectors is not entirely correct.
Most, but not all, of the connectors are similar to a Packard 58.
Basic harness strategy was to bundle the wires for secure attachment with just enough stress relief. Pay attention to how the harnesses are routed and supported.
The wiring strategy is helpful to understand why certain items connect to the loactions they do.
Yes. The seat belt interlock module was 74 ONLY and interrupted the yellow start wire under some conditions. You could rewire it, but there is a fair amount of more wiring added for that stupid seat belt stuff
[/URL]
for example
[/URL]
Can you explain what a fleet alternator is?
A heavy duty option mostly seen on fleet purchases, for example police or taxi. The exact model alternator varied from year to year and application.
Alternator output was split on the engine side of the firewall. One feed going to the battery via the ammeter through a grommet in the firewall. The other feed going to the everything else.
A big clue will the use of a grommet for wires going through the firewall to the ammeter.
Here's an example on an export Swiss '74.
Photos in the link below of the heavy duty version seen with the rear defrost grid.
In this version, the alternator output splits at the ammeter connection.
[/URL][/URL]
So the alternator wiring that is on the duster right now, it goes straight to a connector along with the other 2 wires. The 74 duster harness has a thick black wire which goes into its own connector , like how the picture looks, and the other 2 go to a connector with additional wires. Also my duster doesn’t have rear defrost.
"Fleet" is police, taxi, fleet, optional 65A alternator. There is a LOT of discussion on this board and others about bulkhead connector/ ammeter wiring failures, most particularly, with larger alternators, and the factory optional 65 alternator is somewhat proof that Ma knew this was a problem. In effect it is a form of bulkhead connector bypass, as the terminals in them are limited for current
Also read this:
You don't have to do this in this way, and if yours is in good shape you may not need to, but kit is food for thought
Also read this:
was it a mistake you sending a video about a windmill demolition?
if it doesn't have redefrost and there isn't a grommet with 12 ga or larger wires as shown in the photos above, then it was a standard harness.
OK. I can't see any details in the photo. The Forum is set up for horizontal viewing. There will be less shrinkage with horizonatl photos. Still will be limited in pixels to 800 wide or something like that.
If I understand correctly:
1973 Harness on the car.
The alternator output wire, and the field wires, all go to an engine bay connector. That was done for several years. Reportedly to easy manufacturing. Connections there can be problematic. Especially if , as may be in this case, the wires are hanging free with no support. Worst if over the exhaust.
1974 harness.
Alternator output wire goes to a seperate connector.
When you note differences like that, that's when it time to refer to the diagrams in the shop manuals.
Side note: Fat wire, small wire, and so forth are the begining of the learning curve. Its also pretty hard to translate with any certainty. In this case, the alternator, its not an problem. But all these wires have names and functions which will be very helpful when comparing between the two harnesses.
The heavy black wire is alternator output. Chrysler always labled it R6 on the drawings. R for Alernator.
The blue wire is a segment of the run circuit. It primarily supplies power to the ignition and the alternator's rotor.
The green wire connects to the voltage regulator and controls current allowed through the rotor.
From the '73 service manual. CE = Connector Engine Comparment
R6 12 BK = Alternator wire 6, 12 gage, Black (output wire) note this is always hot since it is joined to battery positive.
R3 18 DGN = Alternator wire 3, 18 gage, dark green (field control)
J2_ 18 DBL = Ignition Run, 18 gage, dark blue. (C, F and G are wire segments or branches)
1974 harness.
From the '74 FSM.
So yes the connections are different. Since you have both halves of the connector, maybe it doesn't matter.
i plan on sending some pictures of both harnesses some time this week into this forum just so anyone who wants to help can see the differences and everything like that. I do appreciate all the help that was already provided, it should help make things easier when putting the harness in.
