I just blew my link last night on the highway
In your case dont do anything more than find what caused the fusible link to burn open. If you start changing a lot of stuff now you may create new problems before finding the 1st one.
The wires on the amp gauge have ring terminals on large wires . They are attached to the gauge posts with toohed washers and hex nuts.
If you want to go ahead and put both wires together on 1 of the gauge studs to take that gauge out of the trouble shooting, that's fine.
Any part store will have fusible links. Theirs wont have the terminals on the ends like your factory link has. You would need to order from Year One to get exact replacement link.
In a case like this I agree with Red completely. Find the SHORT that caused the problem FIRST and fix it, THEN if you want to improve things, go at it.
It also might be that the fuse link blew because of a poor connection right where the link connects to the bulkhead. Read the MAD article, and check out the problem areas they mention
The main problems (look at the diagram 73AbodEE posted above) are:
Too small wire in the charging line for larger alternators and heavy added loads
Poor connections in the bulkhead connector
Poor connections and problems with the ammeter
The "welded splice" CAN fail
WHAT YOU ARE DOING with the "simple" bypass in the MAD article, is you are effectively putting the alternator ORIGINAL charge wire (black, through the bulkhead) and the orginal battery feed (red, through the bulkhead) in PARALLEL, which has instandly DOUBLED the size of the wire feeding power INTO the interior of the car, while at the same time, the BATTERY charging current no longer has to flow through that wiring because of the bypass.
The whole article is here:
http://www.madelectrical.com/electricaltech/amp-gauges.shtml
More from the same place:
http://www.madelectrical.com/electrical-tech.shtml
Red mentioned an ammeter to voltmeter conversion earlier. I've done the same, here's a thread on that:
http://www.forabodiesonly.com/mopar/showthread.php?t=119480&highlight=ammeter+conversion
